bananapim2plus
Standard support
Desktop
Armbian 26.2.1 XFCE
Kernel: 6.12.68, Size: 918.7 MB, Release date: Apr 2, 2026
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 26.2.1 Minimal / IOT
Kernel: 6.12.68, Size: 254.4 MB, Release date: Apr 2, 2026
Build Date: Apr 2, 2026
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 241.2 MB
Debian Testing (Sid) Kali Linux SHA    ASC 499.7 MB
Debian 13 (Trixie) Home Assistant SHA    ASC 496.7 MB
1000tx 1wire 32bit 4 core CAN UASP bluetooth docker eMMC i2c i2s spi wifi wireguard Allwinner H3
Debian 14 (Forky) Minimal / IOT rolling 6.18.20 SHA  ASC 261.9 MB
Ubuntu 24.04 (Noble) XFCE stable 6.18.20 SHA  ASC 819.5 MB
