- Boot log for 25.2.1: https://paste.next.armbian.com/ejoquhemak
- Gigabit Ethernet transfer rate is around 50% of its theoretical max rate (internal chip bus limitation)
After you download and boot?
armbian-config
Server images with Armbian Linux v6.6
Build Date: Feb 13, 2025
Server / CLI | ![]() |
SHA | ASC | 423.7 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 259.2 MB | ||||||
SHA | ASC | 237.7 MB | ||||||
SHA | ASC | 269.7 MB | ||||||
1000tx 2 core 2GB 32bit 4 core 4GB SPDIF bluetooth esata wifi wireguard NXP Freescale i.MX 6
- join community forums
