nanopineo
Community maintained
After you download and boot?
armbian-config
Server images with Armbian Linux v6.6
Build Date: Mar 17, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 392 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 240.2 MB
100tx 1wire 32bit 4 core CAN UASP docker i2c spi wireguard Allwinner H3
