odroidc2
Standard support
Minimal
Armbian 25.2.1 Bookworm Minimal / IOT
Kernel: 6.12.13, Size: 255.9 MB, Release date: Feb 13, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.1 Noble Gnome
Kernel: 6.12.13, Size: 1.2 GB, Release date: Feb 13, 2025
After you download and boot?
armbian-config
Build Date: Feb 13, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.5 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 484.7 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 246.7 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 386.3 MB
1000tx 2GB 4 core 64bit UASP docker eMMC i2c wireguard S905 Amlogic
