odroidxu4
Standard support
Minimal
Armbian 25.5.1 Bookworm Minimal / IOT
Kernel: 6.6.88, Size: 231.4 MB, Release date: May 21, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.5.1 Bookworm XFCE
Kernel: 6.6.88, Size: 1.1 GB, Release date: May 21, 2025
For HC1 and HC2 we provide specially optimized config which you can enable via armbian-config -> system -> kernel -> select odroid configuration. This results in shorter boot time and lower consumption. Manualls – edit or create /boot/armbianEnv.txt and add: board_name=xu4 # or xu3, xu3, hc1
Overlay management via armbian-config is not supported. You need to edit /boot/boot.ini and add overlays manually. Look for a line:
setenv overlays "i2c0 i2c1 hktft-cs-ogst"
Here you add what you need. More you can find in /boot/dtb/ or /boot/dtb/overlays
Make sure to adjust path in
ext4load mmc 0:1 0x60000000 /boot/dtb/overlays/${overlay}.dtbo
accordingly.
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: May 21, 2025
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Server images with Armbian Linux v6.6
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 408.9 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 221.8 MB
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 308.1 MB
Compatible
HC1 HC2 MC1
1000tx 2GB 32bit 8 core UASP docker eMMC usb3 Samsung Exynos 5422
Rolling releases images with Armbian Linux v6.6
Build Date: May 20, 2025
Debian 12 (Bookworm) XFCE stable 6.6.88 SHA  ASC 701.8 MB
Ubuntu 24.04 (Noble) Minimal / IOT stable 6.6.88 SHA  ASC 221 MB
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.6.88 SHA  ASC 232.6 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.6.88 SHA  ASC 237.7 MB
