orangepilite
Community maintained
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Feb 20, 2025
Ubuntu 24.04 (Noble) XFCE SHA    ASC 866.1 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 243.1 MB
1wire 32bit 4 core CAN UASP docker i2c spi wifi wireguard Allwinner H3
