After you download and boot?
armbian-config
Build Date: Feb 20, 2025
XFCE | ![]() |
SHA | ASC | 866.8 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 228.4 MB | ||||||
1000tx 1wire 2GB 32bit 4 core CAN UASP docker eMMC i2c i2s spi wifi wireguard Allwinner H3
- join community forums
