orangepizero
Community maintained
  • Onboard wireless module (XR819) has poor software support so wireless connection issues are expected
  • Orange Pi Zero rev 1.4 reports false high CPU temperatures.
After you download and boot?
armbian-config
Build Date: Dec 24, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 417.1 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 240.6 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 234.9 MB
Debian 13 (Trixie) Minimal / IOT SHA    ASC 266.4 MB
100tx 1wire 32bit 4 core CAN UASP docker i2c spi spi flash wifi wireguard Allwinner H2+
