Community maintained
What Does Community Support Mean?
Community maintained targets have full featured Armbian OS support but lack quality control imposed by Armbian standard support criteria. Boards are supported / maintained at least on the level of 3rd party Linux distributions. They are maintained (or not maintained) by community members (like you). These builds are provided by the Armbian project as a service to the community. They are automatically generated and untested.
What you can do to help lifting support status?
After you download and boot?
Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user and confirm your, automatically determined, language settings. If your hardware has internal media, you might want to transfer your OS to it. You can also choose to configure your OS first, setup applications, enable services and install to internal media later.
armbian-config
You can select different login shell (ZSH), enable 2FA for your SSH, enable virtual read-only file-system, switch to rolling releases, ... and more. Armbian config tool helps you configure your network (static, dynamic, enabling hotspot). Once you are done configurion your OS, you can proceed to software section. Armbian config provides clean and fast way of installing great selection of popular software titles. If you plan to use your board for running a home automation, file server, ad blocking, downloading media, ... we got you covered.
Server images with Armbian Linux v6.6
Build Date: Apr 3, 2025
Distro Variant Extensions Torrent Integrity Size
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 426.5 MB
* Server / CLI images comes with Network Manager and include packages like armbian-config, armbian-zsh etc.
Minimal/IOT images with Armbian Linux v6.6
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 237.4 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Become a partner and support development!
Specifications
1000tx 1wire 4 core 64bit UASP docker eMMC i2c i2s spi wifi wireguard Allwinner H5
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
