rockpro64
Community maintained
Alternatives with better software support
Minimal
Armbian 25.2.1 Bookworm Minimal / IOT
Kernel: 6.12.13, Size: 249.7 MB, Release date: Feb 13, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.1 Noble Gnome
Kernel: 6.12.13, Size: 1.2 GB, Release date: Feb 13, 2025
What Does Community Support Mean?
Community maintained targets have full featured Armbian OS support but lack quality control imposed by Armbian standard support criteria. Boards are supported / maintained at least on the level of 3rd party Linux distributions. They are maintained (or not maintained) by community members (like you). These builds are provided by the Armbian project as a service to the community. They are automatically generated and untested.
What you can do to help lifting support status?
  • UART is accessible on pin 6 (GND),8 (TX) and 10 (RX) and with unusual speed: 1500000
  • flash the 128M SPI memory to also boot from USB or PXE (it if goes wrong, follow these instructions)
  • short-pressing (~1s) the power button turns the board on, long-pressing it (~3s) turns it off. If it gets stuck while halting, press the reset button. If it does not boot (ie the white led does not come up), reset, then power on.
  • if you experience USB3 storage lack of reliability (error messages followed by filesystem corruption), check your power supply, usb cable and connectors and disk/ssd. All these factors can lead to undervoltage issues (some ssd could produce power consumption spikes triggering undervoltage).
After you download and boot?
Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user and confirm your, automatically determined, language settings. If your hardware has internal media, you might want to transfer your OS to it. You can also choose to configure your OS first, setup applications, enable services and install to internal media later.
armbian-config
You can select different login shell (ZSH), enable 2FA for your SSH, enable virtual read-only file-system, switch to rolling releases, ... and more. Armbian config tool helps you configure your network (static, dynamic, enabling hotspot). Once you are done configurion your OS, you can proceed to software section. Armbian config provides clean and fast way of installing great selection of popular software titles. If you plan to use your board for running a home automation, file server, ad blocking, downloading media, ... we got you covered.
Desktop images with Armbian Linux v6.12
Build Date: Feb 13, 2025
Distro Variant Extensions Torrent Integrity Size
Debian 12 (Bookworm) Cinnamon SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.1 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Server images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 479.7 MB
* Server / CLI images comes with Network Manager and include packages like armbian-config, armbian-zsh etc.
Minimal/IOT images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 245.8 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 245.7 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Dedicated applications images with Armbian Linux v6.12
Build Date: Mar 6, 2025
Distro Application Torrent Integrity Size
Debian 12 (Bookworm) Home Assistant SHA    ASC 316.1 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 331.3 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 537 MB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Help Armbian Grow: Support & Join Our Team!
Specifications
1000tx 2GB 4GB 6 core 64bit UASP docker eMMC i2c pci usb-c usb3 wifi wireguard Rockchip RK3399
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
