tritium
Standard support
Minimal
Armbian 25.2.2 Bookworm Minimal / IOT
Kernel: 6.6.75, Size: 241.9 MB, Release date: Feb 28, 2025
SHA hash | PGP signature
Stable user space packages
Minimal
Armbian 25.2.2 Noble Minimal / IOT
Kernel: 6.6.75, Size: 230.9 MB, Release date: Feb 28, 2025
After you download and boot?
Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user and confirm your, automatically determined, language settings. If your hardware has internal media, you might want to transfer your OS to it. You can also choose to configure your OS first, setup applications, enable services and install to internal media later.
armbian-config
You can select different login shell (ZSH), enable 2FA for your SSH, enable virtual read-only file-system, switch to rolling releases, ... and more. Armbian config tool helps you configure your network (static, dynamic, enabling hotspot). Once you are done configurion your OS, you can proceed to software section. Armbian config provides clean and fast way of installing great selection of popular software titles. If you plan to use your board for running a home automation, file server, ad blocking, downloading media, ... we got you covered.
Desktop images with Armbian Linux v6.6
Build Date: Feb 28, 2025
Distro Variant Extensions Torrent Integrity Size
Debian 12 (Bookworm) XFCE SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Server images with Armbian Linux v6.6
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 405.4 MB
* Server / CLI images comes with Network Manager and include packages like armbian-config, armbian-zsh etc.
Specifications
100tx 1wire 32bit 4 core CAN UASP docker eMMC i2c spi wireguard Allwinner H3
FAQs
We provide a selection of images that fits hardware best. If you need different image - use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages - you can build any combination - stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly. Insert the SD card into the slot, connect a cable to your network if possible or a display and power your board. (First) boot (with DHCP) takes a bit longer.
