la-frite
Standard support
Minimal
Armbian 25.2.2 Bookworm Minimal / IOT
Kernel: 6.12.15, Size: 266.3 MB, Release date: Feb 20, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble Gnome
Kernel: 6.12.15, Size: 1.2 GB, Release date: Feb 20, 2025
SPI bootloader update:
  1. Download the firmware update file.
  2. Flash the file to a USB drive
  3. Eject the drive from your computer and plug it into La Frite.
  4. Power on La Frite and it will start updating the firmware.
  5. Do not power off La Frite until the firmware update is complete!
USB Mass Storage Flashing:
  1. Connect La Frite to the host PC with a USB A to USB A cable
    • This is the USB connector closest to the IR sensor and 40 pin connector
    • The other will not work
  2. Connect a USB keyboard to the remaining port on La Frite
  3. While booting, press the <Esc> key to get the boot menu on the device
  4. Select “eMMC USB Drive Mode”.  La Frite will appear as a USB drive on the host PC
  5. On host PC, flash the desired image to the drive.
  6. Disconnect the USB A cable from La Frite (important), reboot
After you download and boot?
Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user and confirm your, automatically determined, language settings. If your hardware has internal media, you might want to transfer your OS to it. You can also choose to configure your OS first, setup applications, enable services and install to internal media later.
armbian-config
You can select different login shell (ZSH), enable 2FA for your SSH, enable virtual read-only file-system, switch to rolling releases, ... and more. Armbian config tool helps you configure your network (static, dynamic, enabling hotspot). Once you are done configurion your OS, you can proceed to software section. Armbian config provides clean and fast way of installing great selection of popular software titles. If you plan to use your board for running a home automation, file server, ad blocking, downloading media, ... we got you covered.
Desktop images with Armbian Linux v6.12
Build Date: Feb 20, 2025
Distro Variant Extensions Torrent Integrity Size
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Server images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 493.4 MB
* Server / CLI images comes with Network Manager and include packages like armbian-config, armbian-zsh etc.
Minimal/IOT images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 245.3 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Dedicated applications images with Armbian Linux v6.12
Build Date: Mar 6, 2025
Distro Application Torrent Integrity Size
Debian 12 (Bookworm) Home Assistant SHA    ASC 329.9 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 540.5 MB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Help Armbian Grow: Support & Join Our Team!
Specifications
100tx 4 core 64bit docker i2c spi flash wireguard Amlogic S805
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
