Notebook
Standard support
Minimal
Armbian 25.2.3 Bookworm Minimal / IOT
Kernel: 6.12.20, Size: 721 MB, Release date: Mar 27, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.3 Noble Gnome
Kernel: 6.12.20, Size: 1.7 GB, Release date: Mar 27, 2025
Better then Ubuntu? No Canonical proprietary solutions. Better then Debian? More recent package base.
Better then both:
  • HiDPI support for GRUB and desktop (automated adjustments on big screen resolutions),
  • immutable firmware (kernel upgrade locked to additionally enhance stability),
  • kernel headers preinstalled (easy additional drivers install),
  • ZFS 2.2.2 ready (apt install zfsutils-linux zfs-dkms),
  • face unlock works perfectly (if your camera is supported),
  • additional (hibernation) power saving method comes pre-configured (since standby doesn't always works),
  • snapd is not installed (user can install it).
Installation to HDD/SSD drive is done by transferring live image to the target (sudo armbian-install).
After you download and boot?
Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user and confirm your, automatically determined, language settings. If your hardware has internal media, you might want to transfer your OS to it. You can also choose to configure your OS first, setup applications, enable services and install to internal media later.
armbian-config
You can select different login shell (ZSH), enable 2FA for your SSH, enable virtual read-only file-system, switch to rolling releases, ... and more. Armbian config tool helps you configure your network (static, dynamic, enabling hotspot). Once you are done configurion your OS, you can proceed to software section. Armbian config provides clean and fast way of installing great selection of popular software titles. If you plan to use your board for running a home automation, file server, ad blocking, downloading media, ... we got you covered.
Desktop images with Armbian Linux v6.12
Build Date: Mar 27, 2025
Distro Variant Extensions Torrent Integrity Size
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 2 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.9 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 2 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.7 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Server images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 956 MB
* Server / CLI images comes with Network Manager and include packages like armbian-config, armbian-zsh etc.
Minimal/IOT images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 714 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Cloud Images images with Armbian Linux v6.12
Distro Variant Type Torrent Integrity Size
Debian 12 (Bookworm) Minimal / IOT (QCOW2) SHA    ASC 693.7 MB
Debian 12 (Bookworm) Minimal / IOT (Hyperv) SHA    ASC 760 MB
Ubuntu 24.04 (Noble) Minimal / IOT (QCOW2) SHA    ASC 652.4 MB
Ubuntu 24.04 (Noble) Minimal / IOT (Hyperv) SHA    ASC 760 MB
Dedicated applications images with Armbian Linux v6.12
Build Date: Mar 6, 2025
Distro Application Torrent Integrity Size
Debian 12 (Bookworm) Home Assistant SHA    ASC 774.6 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 766.1 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.6 GB
Debian Testing (Sid) Kali Linux SHA    ASC 1 GB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Use armbian-config utility to adjust your system settings
Specifications
10000tx 1000tx 100tx 16GB 1wire 2 core 2500tx 2GB 32bit 4 core 4GB 6 core 64bit 8 core 8GB CAN ECC SPDIF UASP battery bluetooth docker eMMC esata i2c i2s m2 mpci msata nand pci sata sfp spi spi flash switch usb-c usb3 wifi wireguard
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
Rolling releases images with Armbian Linux v6.12
Build Date: Apr 16, 2025
Distro Variant User space Kernel Torrent Integrity Size
Debian 12 (Bookworm) Minimal / IOT (QCOW2) stable 6.12.23 SHA  ASC 700.6 MB
Debian 11 (Bullseye) Minimal / IOT (QCOW2) oldstable 6.12.23 SHA  ASC 587.3 MB
Ubuntu 20.04 (Focal) Minimal / IOT (QCOW2) oldstable 6.12.23 SHA  ASC 567.5 MB
Ubuntu 22.04 (Jammy) Minimal / IOT (QCOW2) oldstable 6.12.23 SHA  ASC 590.6 MB
Ubuntu 24.04 (Noble) Minimal / IOT (QCOW2) stable 6.12.23 SHA  ASC 652.4 MB
Ubuntu 25.04 (Plucky) Minimal / IOT (QCOW2) rolling 6.12.23 SHA  ASC 636.4 MB
Debian Testing (Trixie) Minimal / IOT (QCOW2) rolling 6.12.23 SHA  ASC 693.8 MB
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases. They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
