After you download and boot?
Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user and confirm your, automatically determined, language settings. If your hardware has internal media, you might want to transfer your OS to it. You can also choose to configure your OS first, setup applications, enable services and install to internal media later.
armbian-config
You can select different login shell (ZSH), enable 2FA for your SSH, enable virtual read-only file-system, switch to rolling releases, ... and more. Armbian config tool helps you configure your network (static, dynamic, enabling hotspot). Once you are done configurion your OS, you can proceed to software section. Armbian config provides clean and fast way of installing great selection of popular software titles. If you plan to use your board for running a home automation, file server, ad blocking, downloading media, ... we got you covered.
Different images? Missing features? -> Download SDK Looking for compatible accessories? Want to participate in development?
Desktop images with Armbian Linux v6.6
Build Date: Nov 28, 2024
Distro | Variant | Extensions | Torrent | Integrity | Size | |||||
Cinnamon | MESA / VPU | ![]() |
SHA | ASC | 1.4 GB | |||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
Gnome | MESA / VPU | ![]() |
KDE Neon | MESA / VPU | ![]() |
SHA | ASC | 1.6 GB | |||||
XFCE | ![]() |
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc. |
Server images with Armbian Linux v6.6
Server / CLI | MESA / VPU | ![]() |
SHA | ASC | 491.1 MB | |||||
* Server / CLI images comes with Network Manager and include packages like armbian-config, armbian-zsh etc. |
Minimal/IOT images with Armbian Linux v6.6
Minimal / IOT | ![]() |
SHA | ASC | 247.3 MB | ||||||
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments. |
Dedicated applications images with Armbian Linux v6.12
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 322.6 MB | ||||||
OpenHab | ![]() |
SHA | ASC | 1.1 GB | ||||||
Kali Linux | ![]() |
SHA | ASC | 534.9 MB | ||||||
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support. |
Specifications
1000tx 4GB 6 core UASP bluetooth docker eMMC i2c pci usb-c usb3 wifi wireguard Rockchip RK3399
FAQs
- check previous images from archive
- join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
- Free support is provided via general project search engine, documentation, community forums or IRC/Discord. Keep in mind this is mostly provided by our awesome community members in a best effort manner and therefore there are no guaranteed solutions.
- For commercial or prioritised assistance:
- book a an hour of professional consultation,
- consider becoming a project partner.
- Reach us out at https://armbian.com/contact,
Rolling releases images with Armbian Linux v6.12
Build Date: Mar 30, 2025
Distro | Variant | User space | Kernel | Torrent | Integrity | Size | |
Minimal / IOT | rolling | 6.12.21 | ![]() | SHA | ASC | 269.2 MB | |
Minimal / IOT | rolling | 6.12.21 | ![]() | SHA | ASC | 266 MB |
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases.
They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
