Texas Instruments SK-AM62B Development Board
Standard support
Minimal
Armbian 24.11.1 Bookworm Minimal / IOT
Kernel: 6.6.63, Size: 210.9 MB, Release date: Nov 23, 2024
SHA hash | PGP signature
Stable user space packages
CLI
Armbian 24.11.1 Noble Server / CLI
Kernel: 6.6.62, Size: 403.6 MB, Release date: Nov 23, 2024
After you download and boot?
Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user and confirm your, automatically determined, language settings. If your hardware has internal media, you might want to transfer your OS to it. You can also choose to configure your OS first, setup applications, enable services and install to internal media later.
armbian-config
You can select different login shell (ZSH), enable 2FA for your SSH, enable virtual read-only file-system, switch to rolling releases, ... and more. Armbian config tool helps you configure your network (static, dynamic, enabling hotspot). Once you are done configurion your OS, you can proceed to software section. Armbian config provides clean and fast way of installing great selection of popular software titles. If you plan to use your board for running a home automation, file server, ad blocking, downloading media, ... we got you covered.
Bleeding edge images with Armbian Linux v6.6
Build Date: Nov 23, 2024
Distro Variant Extensions Torrent Integrity Size
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 204.8 MB
* Edge kernels are actively developed, so there may be some unreported issues on this images. You should beware of that.
* Most of images are tested with test automation or by Armbian community or official maintainers.
Dedicated applications images with Armbian Linux v6.12
Build Date: Mar 6, 2025
Distro Application Torrent Integrity Size
Debian 12 (Bookworm) OpenHab SHA    ASC 1 GB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Use armbian-config utility to adjust your system settings
Specifications
AM62X
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
Rolling releases images with Armbian Linux v6.6
Build Date: Mar 30, 2025
Distro Variant User space Kernel Torrent Integrity Size
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.6.58 SHA  ASC 266.3 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.6.58 SHA  ASC 278.8 MB
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases. They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
