bananapim7
Standard support
Minimal
Armbian 25.2.1 Bookworm Minimal / IOT
Kernel: 6.1.99, Size: 303.1 MB, Release date: Feb 13, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.1 Noble Gnome
Kernel: 6.1.99, Size: 1.4 GB, Release date: Feb 13, 2025
After you download and boot?
Basic OS configuration is conducted at first boot. You are asked to set a root password, normal user and confirm your, automatically determined, language settings. If your hardware has internal media, you might want to transfer your OS to it. You can also choose to configure your OS first, setup applications, enable services and install to internal media later.
armbian-config
You can select different login shell (ZSH), enable 2FA for your SSH, enable virtual read-only file-system, switch to rolling releases, ... and more. Armbian config tool helps you configure your network (static, dynamic, enabling hotspot). Once you are done configurion your OS, you can proceed to software section. Armbian config provides clean and fast way of installing great selection of popular software titles. If you plan to use your board for running a home automation, file server, ad blocking, downloading media, ... we got you covered.
Desktop images with Armbian Linux v6.12
Build Date: Feb 13, 2025
Most stable mainline based kernel but not all features have been implemented yet.
Distro Variant Extensions Torrent Integrity Size
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.5 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
* Desktops are very simple and minimal but containing standard features such as Chromium, Firefox browser, Office tools etc.
Based on Rockchip BSP. This kernel is newer than the legacy kernel v5.10.y and works stable too.
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.4 GB
Server images with Armbian Linux v6.12
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 507 MB
* Server / CLI images comes with Network Manager and include packages like armbian-config, armbian-zsh etc.
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 493.7 MB
Minimal/IOT images with Armbian Linux v6.12
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 251.9 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 262.2 MB
* Minimal images have very small footprint. They come only with essential packages and build-in systemd-networkd. They are optimised for automation and production deployments.
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 295.8 MB
Dedicated applications images with Armbian Linux v6.1
Build Date: Mar 6, 2025
Distro Application Torrent Integrity Size
Debian 12 (Bookworm) Home Assistant SHA    ASC 312.2 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 314.3 MB
Debian Testing (Sid) Kali Linux SHA    ASC 542.7 MB
* 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support.
Use armbian-install utility to transfer live image to fixed storage
Specifications
Rockchip RK3588
FAQs
  • check previous images from archive
  • join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
Rolling releases images with Armbian Linux v6.1
Build Date: Apr 14, 2025
Distro Variant User space Kernel Torrent Integrity Size
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.1.99 SHA  ASC 245.5 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.1.99 SHA  ASC 258.1 MB
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases. They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
