BeagleY®-AI is a low-cost, open-source, community-supported development platform for developers and hobbyists in a familiar form-factor compatible with accessories available for other popular single board computers. Users benefit from BeagleBoard.org-provided Debian Linux software images with a built-in development environment and the ability to run artificial intelligence applications on a dedicated 4 TOPS co-processor along with real-time I/O tasks on a dedicated 800MHz microcontroller. BeagleY®-AI is designed to meet the needs of professional developers and classroom-environments alike being affordable and easy-to-use, while being open source hardware such that developers barriers are eliminated to how deep the lessons can go or how far you can take the design in practical applications.
Checkout https://pinout.beagley.ai for Pinmuxing and accessory compatibility info.
Fast, verified download & flash (recommended)
Armbian Imager is a lightweight, native flashing tool that supports both selecting and downloading an Armbian image before flashing, as well as flashing an already downloaded image.
Different images? Missing features? -> Download SDK Looking for compatible accessories? Want to participate in development?
Dedicated applications images with Armbian Linux v6.12
Build Date: Mar 29, 2026
| Distro | Application | Torrent | Integrity | Size | ||||||
| Kali Linux | SHA | ASC | 514.7 MB | |||||||
| Home Assistant | SHA | ASC | 530.5 MB | |||||||
| OpenMediaVault | SHA | ASC | 429.7 MB | |||||||
| OpenHab | SHA | ASC | 1.2 GB | |||||||
| * 3rd party unofficial applications deployment made with official Armbian build framework. Application support is not provided by Armbian team, but you are welcome to use our community forums for support. | ||||||||||
Specifications
FAQs
- check previous images from archive
- join community forums
Simple
Universal
Light
Optimized
Fast
Secure
Supported
Open
We provide a selection of images that fits hardware best. If you need different image – use build framework and make whatever you need. Build framework relies on Debian and Ubuntu packages – you can build any combination – stable, old stable or rolling release.
Make sure you have a good & reliable boot media (SD card / USB key) and a proper power supply. Archives can be flashed with Etcher (all OS) directly.
- Free support is provided via general project search engine, documentation, community forums or IRC/Discord. Keep in mind this is mostly provided by our awesome community members in a best effort manner and therefore there are no guaranteed solutions.
- For commercial or prioritised assistance:
- book a an hour of professional consultation,
- consider becoming a project partner.
- Reach us out at https://armbian.com/contact,
Rolling releases images with Armbian Linux v6.12
| Distro | Variant | User space | Kernel | Torrent | Integrity | Size | |
| Minimal / IOT | rolling | 6.12.49 | SHA | ASC | 302.8 MB | ||
| Gnome | stable | 6.12.49 | SHA | ASC | 1.2 GB | ||
* The torrent option is recommended, as it will likely maximize your download connection speed.
Rolling releases are suitable for Linux enthusiasts who want cutting edge packages and have the skills to fix damage that a bad update might cause. If you want stability in a production environment or low headaches as a novice user, skip rolling releases.
They are only at, build and ship, Debian testing / Arch / Manjaro / Suse Tumbleweed / Kali / Gentoo support quality level!
