xt-q8l-v10
Community maintained
Desktop
Armbian 25.5.0-trunk.399 Noble Gnome
Kernel: 6.12.23, Size: 1.1 GB, Release date: Apr 15, 2025
SHA hash | PGP signature
Community user space packages
Desktop
Armbian 25.5.0-trunk.399 Bookworm Gnome
Kernel: 6.12.23, Size: 1.3 GB, Release date: Apr 15, 2025
Welcome to the Armbian Community Builds for Amlogic S9xx based TV Boxes
TV Boxes are not officially supported by the Armbian project.  These builds are maintained by community members (like you).
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.14
Build Date: Apr 15, 2025
Ubuntu 24.10 (Oracular) Gnome SHA    ASC 1 GB
Ubuntu 24.10 (Oracular) XFCE SHA    ASC 956.9 MB
Debian 12 (Bookworm) XFCE SHA    ASC 846.7 MB
Ubuntu 24.04 (Noble) Cinnamon SHA    ASC 1.3 GB
Server images with Armbian Linux v6.14
Ubuntu 24.10 (Oracular) Server / CLI SHA    ASC 449.1 MB
Debian 12 (Bookworm) Server / CLI SHA    ASC 440 MB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 451.6 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 252.5 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 249.3 MB
4 core 64bit wireguard S912 S905Y2 S905W S905D3 Amlogic S905 S905X S922X S905X3
Build Date: Apr 16, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.23 SHA  ASC 253.3 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.23 SHA  ASC 261.2 MB
