After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.14
Build Date: Apr 24, 2025
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
Minimal/IOT images with Armbian Linux v6.14
Minimal / IOT | ![]() |
SHA | ASC | 254.8 MB | ||||||
- join community forums
