Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.4 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 239.1 MB
