avaota-a1
Community maintained
After you download and boot?
armbian-config
Desktop images with Armbian Linux v5.15
Build Date: Apr 15, 2025
Minimal/IOT images with Armbian Linux v5.15
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 201 MB
Allwinner A527
