bananapim2plus
After you download and boot?
armbian-config
Build Date: Apr 28, 2025
Debian 12 (Bookworm) XFCE SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Build Date: Apr 27, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 425.1 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 244.8 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 228.9 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 244.5 MB
1000tx 1wire 32bit 4 core CAN UASP bluetooth docker eMMC i2c i2s spi wifi wireguard Allwinner H3
