bananapiplus
Community maintained
For proper hardware support you need to edit /boot/armbianEnv.txt and add:
fdtfile=sun7i-a20-bananapi-m1-plus.dtb
following by reboot.
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Nov 24, 2024
Debian 12 (Bookworm) XFCE SHA    ASC 1.1 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.1 GB
Server images with Armbian Linux v6.6
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 418.6 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 239.6 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 229.4 MB
1000tx 1wire 2 core 32bit CAN UASP battery bluetooth docker i2c i2s sata spi wifi wireguard Allwinner A20
