After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Minimal / IOT | ![]() |
SHA | ASC | 246 MB | ||||||
1000tx 1wire 2 core 32bit CAN UASP battery docker i2c i2s sata spi wifi wireguard Allwinner A20
- join community forums
