After you download and boot?
armbian-config
Server images with Armbian Linux v6.6
Build Date: Feb 13, 2025
Server / CLI | ![]() |
SHA | ASC | 435.4 MB | ||||||
- join community forums
Rolling releases images with Armbian Linux v6.6
Build Date: Apr 15, 2025
Minimal / IOT | rolling | 6.6.87 | ![]() | SHA | ASC | 239.3 MB |
