bananapim2s
Standard support
Minimal
Kernel: 6.12.15, Size: 256.7 MB, Release date: Feb 22, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble Gnome
Kernel: 6.12.15, Size: 1.2 GB, Release date: Feb 21, 2025
After you download and boot?
armbian-config
Build Date: Feb 21, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Build Date: Feb 22, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 512.8 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 246.1 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 333.3 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Amlogic S922X
Build Date: Apr 16, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.23 SHA  ASC 253.6 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.23 SHA  ASC 269 MB
