After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Minimal / IOT | ![]() |
SHA | ASC | 241.7 MB | ||||||
1000tx 1wire 2GB 32bit 4 core CAN UASP battery bluetooth docker eMMC i2c sata spi wifi wireguard R40 Allwinner
dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb
. In that process you can enforce many customisation.
