- works: serial console, 8 cores, USB, SATA, HDMI, DRM video driver
- A83T chip isn’t SATA capable and therefore the SATA port is provided by a (very) slow GL830 USB-to-SATA-bridge
- https://forum.armbian.com/topic/474-banana-pi-m3/
After you download and boot?
armbian-config
Build Date: Apr 24, 2025
Minimal / IOT | ![]() |
SHA | ASC | 247.8 MB | ||||||
1000tx 1wire 2GB 32bit 8 core CAN UASP battery bluetooth docker eMMC i2c sata spi wifi wireguard Allwinner A83T
dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb
. In that process you can enforce many customisation.
