bananapim4zero
Standard support
Minimal
Kernel: 6.6.75, Size: 234.4 MB, Release date: Feb 27, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble Gnome
Kernel: 6.6.75, Size: 1.2 GB, Release date: Feb 27, 2025
Bluetooth is currently broken.
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Feb 27, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Server images with Armbian Linux v6.6
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 475.3 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 228.6 MB
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 297.3 MB
Allwinner H616
Build Date: Apr 15, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.20 SHA  ASC 256 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.20 SHA  ASC 260.7 MB
