bananapim64
Community maintained
  • Some devices powers off on load
After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 242.6 MB
1000tx 2GB 4 core 64bit UASP battery bluetooth docker eMMC i2c wifi wireguard Allwinner A64
