bananapir2
Desktop
Armbian 26.2.0-trunk.493 XFCE
Kernel: 6.6.127, Size: 828.3 MB, Release date: Mar 15, 2026
SHA hash | PGP signature
Community user space packages
Minimal
Armbian 26.2.0-trunk.493 Minimal / IOT
Kernel: 6.6.127, Size: 279.7 MB, Release date: Mar 15, 2026
Hold power button for about 7-8 seconds to power the device up. Boot log: http://ix.io/1r19
Known problems:
  • HDMI is not working and will probably never,
  • onboard wireless is too fragile, disabled by default.
1000tx 2GB 32bit 4 core docker mpci sata switch usb3 wireguard Mediatek MT7623N
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
