Standard support
The most powerful AI open-source platform available
BeagleBone® AI-64, is built on a proven open source Linux approach, bringing a massive amount of computing power to the hands of developers in an easy to use single board computer. Leveraging the Texas Instruments TDA4VM SOC with dual 64-bit Arm® Cortex®-A72, C7x DSP along with deep learning, vision and multimedia accelerators, developers have access to faster analytics, more data storage options, more high speed interfaces including all the connectors you’ll need on board to build applications such as Autonomous Robotics, Vision and Video Analytics, Hi-End Drones, Media Servers, and Smart Buildings.
BeagleBone® AI-64 brings a complete AI and Machine Learning System to developers with the convenience and expandability of the BeagleBone® platform and the peripherals on board to get started right away learning and rapidly prototyping applications.
Leveraging over a decade of success in open hardware single board Linux computers, BeagleBone® AI-64 puts a massive amount of computing power in an easy to use platform.
After you download and boot?
armbian-config
Rolling releases images with Armbian Linux v6.6
Build Date: Apr 21, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.6.58 SHA  ASC 262.6 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.6.58 SHA  ASC 276.5 MB
