Standard support Platinum support
Minimal
Kernel: 6.6.75, Size: 232.5 MB, Release date: Feb 27, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble XFCE
Kernel: 6.6.75, Size: 1.3 GB, Release date: Feb 27, 2025
After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Feb 27, 2025
Debian 12 (Bookworm) Cinnamon SHA    ASC 1.4 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.5 GB
Server images with Armbian Linux v6.6
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 441.2 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 226.6 MB
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 298.6 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1 GB
Allwinner H616
Build Date: Apr 9, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 6.12.20 SHA  ASC 236.7 MB
Debian Testing (Trixie) Minimal / IOT rolling 6.12.20 SHA  ASC 244.1 MB
