clearfogbase
Community maintained
To boot the image from USB flash:
  • Write the image to a USB flash drive
  • Insert the flash drive into the USB3.0 port
  • Load the modified u-boot (from the Armbian image) using the UART method
  • Stop the default boot sequence
  • Execute in u-boot prompt: run usbboot
To flash the image to eMMC:
  • Boot the image from USB flash
  • Write the image to eMMC using dd or other methods
  • Mount the eMMC partition and add a line emmc_fix=on to /boot/armbianEnv.txt file – this changes the DT during boot to switch from SD with card detect switch to a non-removable eMMC.
  • Unmount the eMMC partition and reboot
Please refer to this forum thread for the USB boot details and this thread for a discussion of known eMMC issues.
After you download and boot?
armbian-config
Server images with Armbian Linux v6.6
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 395.2 MB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 236.9 MB
1000tx 2 core 2GB 32bit docker eMMC i2c m2 mpci sfp switch usb3 wireguard Marvell A388
