After you download and boot?
armbian-config
Server images with Armbian Linux v6.6
Build Date: Mar 28, 2025
Server / CLI | ![]() |
SHA | ASC | 400 MB | ||||||
Build Date: Mar 27, 2025
Minimal / IOT | ![]() |
SHA | ASC | 241.7 MB | ||||||
100tx 1wire 32bit CAN battery docker i2c i2s nand sata spi wireguard Allwinner A10
