devterma06
Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.2 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 248.8 MB
2GB 4GB 6 core 64bit battery bluetooth usb-c wifi Rockchip RK3399
