firefly-rk3399
Community maintained
In case of troubles booting, read this topic.
Enable video and 3D acceleration
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 252.8 MB
1000tx 2GB 4GB 6 core 64bit UASP docker eMMC i2c i2s m2 usb3 Rockchip RK3399
Minimal, server or Desktop. We work with XFCE, Gnome and Cinnamon but more is possible to build: Mate, KDE, Budgie, Deepin, i3, ...
Armbian images and kernels can be made from scratch. Supported environment for build framework is any any X64 based Linux distribution. You can re-make live bootable image or just a kernel+dtb(hardware configuration) package which you transfer to your image and install with: dpkg -i linux-image-[branch]-family.deb linux-dtb-[branch]-family.deb. In that process you can enforce many customisation.
