Community maintained
After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Ubuntu 24.04 (Noble) Gnome SHA    ASC 1.4 GB
Debian 12 (Bookworm) Minimal / IOT SHA    ASC 246.8 MB
Compatible
qqq
32bit 64bit 8 core 8GB aarch64 bluetooth docker eMMC i2s m2 msata sata spi flash usb-c wifi Rockchip RK3588
