After you download and boot?
armbian-config
Server images with Armbian Linux v6.6
Build Date: Feb 13, 2025
Server / CLI | ![]() |
SHA | ASC | 423.7 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 259.2 MB | ||||||
SHA | ASC | 237.7 MB | ||||||
SHA | ASC | 262 MB | ||||||
1000tx 1wire 2 core 2GB 32bit 4 core bluetooth docker eMMC i2c m2 mpci spi wifi wireguard NXP Freescale i.MX 6
- join community forums
