After you download and boot?
armbian-config
Desktop images with Armbian Linux v6.6
Build Date: Feb 27, 2025
Cinnamon | MESA / VPU | ![]() |
SHA | ASC | 1.4 GB | |||||
XFCE | ![]() |
SHA | ASC | 1.4 GB | ||||||
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 1.5 GB | ||||||
Server images with Armbian Linux v6.6
Server / CLI | ![]() |
SHA | ASC | 499.4 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 238 MB | ||||||
Dedicated applications images with Armbian Linux v6.6
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Kali Linux | ![]() |
SHA | ASC | 518.5 MB | ||||||
- join community forums
Build Date: Apr 21, 2025
Minimal / IOT | rolling | 6.12.23 | ![]() | SHA | ASC | 241.7 MB | |
Minimal / IOT | rolling | 6.12.23 | ![]() | SHA | ASC | 259.6 MB |
