JetHub D1
Standard support
Minimal
Kernel: 6.12.15, Size: 261.1 MB, Release date: Feb 24, 2025
SHA hash | PGP signature
Stable user space packages
CLI
Armbian 25.2.2 Noble Server / CLI
Kernel: 6.12.16, Size: 471.5 MB, Release date: Feb 24, 2025
In order to boot Armbian from JetHub D1/D1+ with pre-flashed OS on eMMC you need USB-USB cable and do:
  1. Download Amlogic Burning Tool
  2. Download latest burnable firmware (testing branch)
  3. Flash!
More instructions on https://docs.jethome.ru/controllers/linux/din_rail/index.html
Now you can boot Armbian from eMMC.
After you download and boot?
armbian-config
All download options
Build Date: Feb 24, 2025
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 260.7 MB
100tx 1wire 2GB 4 core 64bit aarch64 bluetooth docker eMMC i2c wifi wireguard Amlogic A113X
