After you download and boot?
armbian-config
Build Date: Apr 10, 2025
Gnome | ![]() |
SHA | ASC | 1.6 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 717.2 MB | ||||||
1000tx 2GB 4 core 4GB 64bit docker usb3 wireguard Nvidia Xavier NX
- join community forums
