After you download and boot?
armbian-config
Build Date: Apr 15, 2025
Gnome | ![]() |
SHA | ASC | 1.2 GB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 259.2 MB | ||||||
1000tx 1wire 4GB 6 core 64bit UASP battery bluetooth docker eMMC i2c i2s m2 pci spi spi flash usb-c usb3 wifi wireguard Rockchip RK3399
- join community forums
