khadas-vim1
Standard support
Minimal
Kernel: 6.12.17, Size: 268.1 MB, Release date: Feb 28, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble Gnome
Kernel: 6.12.17, Size: 1.2 GB, Release date: Feb 28, 2025
To be able to boot Armbian SD card image and install Armbian to eMMC, use one of the methods to boot into upgrade mode. If you have most recent board revision (1.4 ->) then you only need to quickly press the function key (middle) 3 times in 2 seconds. Release and boot will proceed from SD card. Then use nand-sata-install utility to flash to eMMC.
Serial console:
Blue color line: Tool Pin TXD, orange color: Tool Pin RXD, black: Tool Pin GND
After you download and boot?
armbian-config
Build Date: Feb 28, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.5 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.6 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.3 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 507.6 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 263 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 317 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 327.8 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 532.7 MB
100tx 1wire 2GB 4 core 64bit bluetooth docker eMMC i2c i2s usb-c wifi wireguard Amlogic S905X
