Standard support Platinum support
Minimal
Armbian 25.2.3 Bookworm Minimal / IOT
Kernel: 5.15.137, Size: 279.8 MB, Release date: Mar 6, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.3 Noble Gnome
Kernel: 5.15.137, Size: 1.3 GB, Release date: Mar 6, 2025
After you download and boot?
armbian-config
Desktop images with Armbian Linux v5.15
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Cinnamon SHA    ASC 1.6 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.7 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.4 GB
Server images with Armbian Linux v5.15
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 516.9 MB
Minimal/IOT images with Armbian Linux v5.15
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 275.7 MB
Dedicated applications images with Armbian Linux v5.15
Debian Testing (Sid) Kali Linux SHA    ASC 574.2 MB
Debian 12 (Bookworm) Home Assistant SHA    ASC 357.2 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Amlogic S905Y2
Rolling releases images with Armbian Linux v5.15
Build Date: Apr 21, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 5.15.137 SHA  ASC 278.6 MB
Debian Testing (Trixie) Minimal / IOT rolling 5.15.137 SHA  ASC 290.8 MB
