Serial console:
Blue color line: Tool Pin TXD, orange color: Tool Pin RXD, black: Tool Pin GND
How to boot from SD card? After power on, quickly press the Function key 3 times in 2 seconds, then release the key. More at official manual.
After you download and boot?
armbian-config
Build Date: Feb 28, 2025
Cinnamon | MESA / VPU | ![]() |
SHA | ASC | 1.5 GB | |||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 1.6 GB | ||||||
XFCE | ![]() |
Server / CLI | ![]() |
SHA | ASC | 497.8 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 261.4 MB | ||||||
Build Date: Mar 6, 2025
Distro | Application | Torrent | Integrity | Size | ||||||
Home Assistant | ![]() |
SHA | ASC | 316 MB | ||||||
OpenMediaVault | ![]() |
SHA | ASC | 328 MB | ||||||
OpenHab | ![]() |
SHA | ASC | 1.1 GB | ||||||
Kali Linux | ![]() |
SHA | ASC | 543.8 MB | ||||||
1000tx 1wire 2GB 4 core 64bit bluetooth docker eMMC i2c i2s usb-c wifi wireguard S912 Amlogic
- join community forums
