khadas-vim3
Standard support
Minimal
Kernel: 6.12.15, Size: 304.3 MB, Release date: Feb 20, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble Gnome
Kernel: 6.12.15, Size: 1.4 GB, Release date: Feb 20, 2025
In order to boot Armbian from VIM3 with pre-flashed OS on eMMC you need to:
  1. Download Khadas Rescue tool for VIM3 and flash it to a spare SD card
  2. Insert SD card, attach USB keyboard + monitor or a serial console and boot into Khadas Rescue Tool
  3. Choose: Advanced -> eMMC -> Fast erase and Advanced -> Erase SPI Flash (Yes). Go back and select "power off"
Now you can boot Armbian from SD card and install to eMMC the standard way.
After you download and boot?
armbian-config
Build Date: Feb 20, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.6 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.8 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 566.1 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 295.3 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 379.6 MB
Debian 12 (Bookworm) OpenMediaVault SHA    ASC 389.9 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 601.8 MB
1000tx 1wire 4 core 4GB 64bit bluetooth docker eMMC i2c i2s m2 pci spi spi flash wireguard Amlogic S922X
