khadas-vim3-l
Standard support
Minimal
Kernel: 6.12.15, Size: 302.4 MB, Release date: Feb 21, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble Gnome
Kernel: 6.12.15, Size: 1.4 GB, Release date: Feb 20, 2025
Installation:
  • Download Khadas Rescue system (flash to SD card, insert, power on, hold FUNCTION and short press RESET button)
  • Download Armbian image and place it to the USB drive (copy .xz or .img file, do not flash with Etcher)
  • Boot into Khadas OOWOW and install to eMMC by selecting image from USB drive
After you download and boot?
armbian-config
Build Date: Feb 20, 2025
Debian 12 (Bookworm) Cinnamon MESA / VPU SHA    ASC 1.6 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.8 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.4 GB
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 575.1 MB
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 293.8 MB
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 377.9 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 603 MB
Amlogic S905D3
