khadas-vim4
Standard support Platinum support
Minimal
Kernel: 5.15.137, Size: 282.1 MB, Release date: Feb 24, 2025
SHA hash | PGP signature
Stable user space packages
Desktop
Armbian 25.2.2 Noble Gnome
Kernel: 5.15.137, Size: 1.3 GB, Release date: Feb 24, 2025
KDE Neon desktop is currently broken. Please use different one, until this gets fixed.
After you download and boot?
armbian-config
Desktop images with Armbian Linux v5.15
Build Date: Feb 24, 2025
Debian 12 (Bookworm) Cinnamon SHA    ASC 1.6 GB
Debian 12 (Bookworm) XFCE SHA    ASC 1.5 GB
Ubuntu 24.04 (Noble) KDE Neon SHA    ASC 1.7 GB
Ubuntu 24.04 (Noble) XFCE SHA    ASC 1.4 GB
Server images with Armbian Linux v5.15
Ubuntu 24.04 (Noble) Server / CLI SHA    ASC 513.9 MB
Minimal/IOT images with Armbian Linux v5.15
Ubuntu 24.04 (Noble) Minimal / IOT SHA    ASC 275.4 MB
Dedicated applications images with Armbian Linux v5.15
Build Date: Mar 6, 2025
Debian 12 (Bookworm) Home Assistant SHA    ASC 359.5 MB
Debian 12 (Bookworm) OpenHab SHA    ASC 1.1 GB
Debian Testing (Sid) Kali Linux SHA    ASC 572.6 MB
A311D2
Rolling releases images with Armbian Linux v5.15
Build Date: Apr 21, 2025
Ubuntu 25.04 (Plucky) Minimal / IOT rolling 5.15.137 SHA  ASC 279.2 MB
Debian Testing (Trixie) Minimal / IOT rolling 5.15.137 SHA  ASC 290.8 MB
