After you download and boot?
armbian-config
Build Date: Apr 1, 2025
Cinnamon | ![]() |
SHA | ASC | 1.4 GB | ||||||
XFCE | ![]() |
SHA | ASC | 1.3 GB | ||||||
KDE Neon | ![]() |
SHA | ASC | 1.5 GB | ||||||
XFCE | ![]() |
Server / CLI | ![]() |
SHA | ASC | 455.7 MB | ||||||
Minimal / IOT | ![]() |
SHA | ASC | 224.1 MB | ||||||
- join community forums
